Old 04-09-2021, 09:19 PM   #1
Coachwork: International (Navistar)
Chassis: 37' FE Flatnose 3800FC
Engine: 7.6L DT466 with Allison MD 3060
Solar Prep
We have a 2002 flat nose International. We eventually want to install solar (if I can ever figure out our needs and can come up with the money for it). However at this time it's just not in the budget. We have insulated the floor and put tongue & groove plywood down, used a ton of 2x2's to frame out the ceiling and walls and are getting ready to put installation in walls and ceiling. Oh yeah we have about half the electrical wiring installed. My long winded question is do we need to install those runner/rack things on the roof to attach solar panels to later, before we seal the ceiling up or can we wait until later when we can afford solar? If we wait, how do you then attach the racks, without damaging your ceilings or wiring? I know, probably a stupid question with an obvious answer.
Maggie01 is offline   Reply With Quote
Old 04-09-2021, 09:30 PM   #2
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
My opinion:
Install what is called "strut channel" in the roof/ceiling BEFORE sealing it up. The beauty of the stuff is how versatile it is, you can use it to attach anything, anywhere you want. I would install two runs along the length of the bus near the top, probably around 30"-45" apart, 15"-22.5" off center depending on your ceiling. Use 1/2" bolts with lock nuts, bolt facing up. Washers on the inside if they will fit. Cover them in lap sealant up top as you torque them down.
It is especially important to do this if you are ripping out the ceiling, before closing the ceiling back up. Why? To test for leaks with all those new holes. Spray it with a hose after it dries if you can't wait for a rainy day.
If I were doing it again, I'd also put strut channel along the walls just under the windows for the full length of the bus, as well as strut channel just above the window before the curve starts. This stuff is unbelievably useful- use it to mount ladders, lights, a canopy, a fold-up outdoor table for barbecuing, even decks.
kazetsukai is offline   Reply With Quote
Old 04-09-2021, 09:38 PM   #3
s2mikon's Avatar
Engine: Cummins 8.3
I used rivnuts 5/16” into the roof to hold down unistrut. I put butyl tape between the unistrut and the roof and then covered with sikaflex.
s2mikon is online now   Reply With Quote
Old 04-10-2021, 07:27 AM   #4
We used Blind Bolts (similar to Rivnuts, I think?) to fasten L-brackets, which support the solar racking. If we'd had access to inside face of the roof though, I'd probably have done a more fairlsafe setup. We haven't had any problems in over 2 years and the Blind Bolts were so easy to install.
Old 04-10-2021, 12:48 PM   #5
I would glue down the unistrut. Only downside is now you can't remove it.
Old 04-10-2021, 12:55 PM   #6
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
my plan is the blind bolts as already mentioned.
Old 07-22-2021, 12:07 PM   #7
Originally Posted by kazetsukai View Post
My opinion:
If you donít mind, could you elaborate the size of these strut channels that would result in the most secure support for the panels? Iím a newbie currently planning my conversion project and am trying to figure out what all I need for preparation.
8ri-8ri is offline   Reply With Quote
Old 07-22-2021, 12:23 PM   #8
kazetsukai's Avatar
Rated Cap: 76
Originally Posted by 8ri-8ri View Post
If you don’t mind, could you elaborate the size of these strut channels that would result in the most secure support for the panels? I’m a newbie currently planning my conversion project and am trying to figure out what all I need for preparation.
What do you mean by size? You mean full-depth versus half depth, or do you mean length?
Any strut you find in the home improvement store in the electrical section is going to be stronger than your panels...
Old 07-22-2021, 12:24 PM   #9
I through-bolted 15/16 Unistrut with stainless carriage bolts through the ribs, head on the inside. It’s helpful to know the panel dimensions when you place the Unistrut.
Danjo is online now   Reply With Quote
Old 07-22-2021, 12:28 PM   #10
You can get galvanized unistrut at the Home Depot or other big box. You can get aluminum strut at an industrial supply like Grainger. It’s gonna cost though. Unfortunately strut nuts are just anodized, but it should be ok for years. Just use stainless bolts and blue loctite
Old 07-22-2021, 12:32 PM   #11
When I did the through bolts I used neoprene-backed stainless fender washers and UV-grade Sikaflex against the roof surface, then the strut, then a double-thick stainless washer inside the strut channel and a nylock nut
Old 07-23-2021, 02:29 AM   #12
Every factory RecreationVehicle [spit] has holes in the roof [spit].
Vents, fans, air-conditioner(s).
And they all always leak.
Sky-lights above the bed.
Do not get me started on sky-lights above the bed [gnashes teeth, rends hair].
If I was me, I would look into a clamp system to connect onto the drip-rail.
On our ExpeditionVehicle, we mounted a commercial box.
The factory roof connects to the exterior walls using an aluminum extruded 'I-beam'.
The exterior edges of that 'I' are un-used, so I drilled and bolted through it.
What did I bolt to it?
My cross-members for the photovoltaic panels.
I glued the conduct for the cables across the roof and down the rear wall using my favorite sealer, Vulcum 116.
'Yes', Vulcum 116 is promoted as a sealer, but removing my conduit would require three body-builders or one husky farm-girl.
And would probably take most of the weekend.
LargeMargeInBaja is offline   Reply With Quote
