Old 08-10-2023, 08:42 AM   #1
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
Solar Roof rack
My intentions at this point are to use the IronRidge solar racking system.
Chuck Cassady (Chrome Yellow) uses the XR-1000 rails with IronRidge "L" brackets and a home made spacer.
I contacted Sojourners Way, LLC-- as he makes an aluminum roof mounting bracket (pre bent to match the contour of the roof) to use with the IronRidge rail system, but he said the XR-100 rail (maybe lower profile or lighter weight) would be perfect for this application.
Either solution would be through bolted through the hat channel.
Which way would you go?
PorchDog is offline   Reply With Quote
Old 08-10-2023, 01:44 PM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
they are both rated to 160MPH anchored at 4ft. If you are screwing into every rib, then go with the cheapest, XR-100. If you are going to anchor in every other rib, then go with the XR-1000.
https://www.ironridge.com/component/xr-rails/
Old 08-10-2023, 06:17 PM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Jonathan (Sojourner's Way) has a good, proven system...although I make my own brackets with a larger foot surface area. I also really like the IronRidge rails and, yes, the XR-100 is just fine. Along with the UFO (Universal Fastening Objects) they make for a strong and adjustable system. Be sure to get the end UFO Stopper Sleeves for the panel fasteners on each end of the array.
Old 08-10-2023, 07:22 PM   #4
Rated Cap: 34
I ordered the XR-100 rails today. The closest dealer (City Electric Supply-- a chain) was 100 miles away. They don't stock the IronRidge stuff-- but the guys there told me they would ship the rails to my home for free-- which I thought was too good to be true. $93.00 tax paid for two 14 foot rails.
We'll see how this goes.
I have not ordered any brackets yet.
Thanks for both of these replies.
I have likened my bus project to Noah building the Ark. Not real sure what I will do with it -- if ever finished-- but I enjoy the process. I have learned a lot on the journey so far-- and more learning to come... for a 65 year old...
