We plan on 3-4 thousand watts on the roof, perhaps more, with the intent being that the entire roof be covered by solar panels, a center wood walkway, and wood over any areas not covered by panels or used by vents and hatch. The entire structure will be above the existing bus roof by several inches to provide a means of shielding the roof from solar heat as well as providing air flow between the roof and underside of the panels/decking in order to provide heat dissipation.
While this will provide more power than our batteries can hold on a bright sunny day, it will also allow use of both mini split AC's as well as other loads while still charging the batteries AND on those days with poor solar production, will do better than a minimal array in maintaining available battery power.
