Old 07-10-2020, 04:38 PM   #1
Chassis: Saf-T-Liner MVP
Engine: Cummins
Speedometer not working, can’t find sensor
The speedometer stopped reading and a cel for it popped up not too long after. I can’t find the sensor anywhere. Not on the back end of the trans. Not in the rear diff. Any clue where the bus is getting a reading from?
I have a 99 Thomas built with a Cummins 5.9 and mt643.
dspizzle is offline   Reply With Quote
Old 07-15-2020, 10:20 AM   #2
Engine: Cummins
Nobody has a clue where the sensor might be?
Old 07-21-2020, 04:59 PM   #3
Year: 1955
Coachwork: Chevy
Chassis: 6700
Engine: 327
There's a picture in this thread:
https://www.skoolie.net/forums/f33/s...ion-28564.html
Bluesky is offline   Reply With Quote
Old 07-21-2020, 07:08 PM   #4
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
mt643
i think you have two possibilities. both are on the transmission. probably near the rear of the transmission.
1) a cable that drives a mechanical speedometer.
2) an electrical device that puts out a signal to an electric speedometer.
I dont have this kind of transmission, I have not seen this for certain, nor have I looked.
william
Old 07-21-2020, 09:49 PM   #5
Engine: Cummins
Yea. I see where it normally is on the back side of the trans. But the only sensors in mine are the trans temp sensors and the neutral safety switch.
speed sensor, speedometer, tansmission, thomas 1999
