If you want to stack vertically, you will need a **very** well designed and robust welded rack, through-bolted to load-bearing framing or the floor.
Not a great idea IMO.
Originally Posted by sepudo
I have 6 100ah AGM gel batteries from renogy that I'm debating how to arrange in my bus. I don't know if I should do all 6 or start with 4,5 for starters
6x 12V batteries all in parallel?
Not a great idea.
If 6V so 2P3S layout to get 300Ah @12V, that's marginal but OK.
You really want to keep to 2 strings for optimal balancing of the current flow. 3 is the max IMO but going past 4 is likely going to reduce longevity a fair bit.
Plus 6V units are more robust last longer anyway.
The best GEL are Sonnenschein, made in Germany.
Deka makes decent ones under license in the US, hopefully Renogy is re-labeling either of those.
