My bus had a parasitic load that kept draining the starter batteries. For a while I kept a socket wrench handy and manually disconnected the batteries each time I parked the bus. That got old fast. From the Thomas dealer I bought a Cole Hersee kill switch and thick-as-your-thumb 0/4 cable. Also a hydraulic crimper. (It's a fire hazard if the cables are too thin and the ring connectors aren't crimped tightly.)
I didn't want the hassle of opening the battery compartment to access the kill switch, so I installed it next to the driver's seat. You need to interrupt only the ground (black) cable, but I also ran the positive (red) cable into the switch box I built. Why? I'll be installing a DC-to-DC converter so the alternator can charge the house batteries while I drive. I now have those connections inside the passenger compartment.
With apologies for the 34 minute run time, I made a video about the kill switch installation:
https://youtu.be/ojxiIze_ORU
