Stock set up question: will accessories battery also drain main vehicle battery
Hi all-- I've got a 2009 E450 shuttle bus that I'm in the process of converting. There are two batteries currently in a side panel battery box. Next to the driver seat there's a battery cut off for all accessories (double door opener, interior lights, wheelchair lift, etc.) It seems fairly obvious that both batteries are charged by the alternator and that would be a standard set up. However, my question is this: when the vehicle is off, if you were to run the accessories to the point of draining the "accessories" battery would it then start draining the "vehicle" battery?
Is there a way to have both charged by an alternator but to have separate power draws? If so, how can I tell if my bus is set up that way?
Thank you!
