Old 04-08-2021, 12:05 PM   #21
Rivetboy's Avatar
Originally Posted by Rwnielsen View Post
I can't seem to let it go either. I could live with a fixed tilt, timed rotation, I just need a sturdy base that will rotate 90 degrees or so
I built a "G" scale turntable out of one of these. They are very robust to say the least. It was weatherised with a Tupperware bowl and grommets for the turntable shaft and the handcrank.
https://www.google.com/imgres?imgurl...MygIegUIARDVAg
Rivetboy is offline   Reply With Quote
Old 04-08-2021, 03:30 PM   #22
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
This "Lazy Susan" is the key to the whole process. Do you have any ideas on that?
Rwnielsen is offline   Reply With Quote
Old 04-08-2021, 04:30 PM   #23
Rwnielsen's Avatar
Rated Cap: U/K
This "Lazy Susan" is the key to the whole process. Do you have any ideas on that? I ordered an 8" seat base to play with. If I tilt the panel and keep the weight centered I think it will be worth a shot. It's rated for 400#
Old 04-08-2021, 06:30 PM   #24
Rivetboy's Avatar
Heck, the worst that could happen... Don't know how weather proof that is but shoot why not? Another idea a disc brake rotor and bearings off a kia or similar throw away car? A small tire rim with an axle welded to a flange*
Old 04-08-2021, 10:18 PM   #25
Rwnielsen's Avatar
Rated Cap: U/K
I want to keep it as close to the roof as possible for, you know, drafting other busses on the straights.
