Originally Posted by Jolly Roger bus 223
you have another fuse block with all the light wiring above the dash? or at least in my 2004.
otherwise i would say its a lazy brake pedal return spring? pull up on the pedal and see if they shutoff. could be a bad brake pedal switch as well.
the fuse box under the seat is always fun?
i have the manual for 98-2010 and only half of my wiring matches what i had when i got my bus but everything is labled every foot of the wiring if it is collins body wiring.
my 04 everything bus body wiring runs down the drivers side to the rear for all of that.
might have some pics of mine.
Thanks for such a quick response! Well, I did have a few fuse blocks above the windshield, which I thought only the child warning lights were routed to. But, now I'm thinking I could have deleted a wire to the break lights by mistake and that may be the reason they are on. I also didn't take any pictures of the fuse board before dismantling 🤦🏻*♂️ rookie mistake. If you have any pictures of yours you would be willing to share, that may be able to help me deduce the issue.
I had my mechanic check out the break switch, so I'm pretty sure it's not that and he also double checked the fuses after I did. But, didn't want to pay him a bunch of money to delve any further.
