Old 05-27-2024, 09:14 PM   #1
Chassis: 84 passenger
Engine: C7
Thomas
07 Thomas bus starts some time ,then it does' t new battery's. turn key buzzer on gauges all move. then a click and no start. turn key off, retry and get nothing. try again nothing ,gauge don t move no buzzer. may start if I tough the accelerator but not all the time. don t think its the interlock because it starts???? thanks
kodiak_jack is offline   Reply With Quote
Old 05-30-2024, 07:18 PM   #2
Try wiggling the gear shift. Make sure it's set in neutral, but wiggle it. Also, check all your emergency exits. The back door can't be locked shut with the bolt.
britpotato is offline   Reply With Quote
Old 05-30-2024, 07:29 PM   #3
ewo1's Avatar
Don't forget the obvious...dirty / loose battery terminals....
