Turn signal problem- help!
Hey all!
I have gone through all the wires, removed a ton and I'm down to what I think is finally the last wire. Everything works! Except... when I turn on the turn signal to turn right, right side (rear) lights blink as they should, when I turn on the signal to the left... right-side lights blink, but not the left. Running lights, brake lights, backup lights all work. My light monitor is reconnected. It seems a simple switch of cables or maybe moving one cable should fix this but I can't figure it out. Please help! I'm so close.
There is a 4-way connection just before the light monitor with two brown and two white cables that all connect via a small metal piece that I have never seen before. I feel like the problem is here, but again I can't find the solution. Thanks so much for any help you can offer!
