Old 01-08-2020, 10:58 PM   #1
Year: 2005
Coachwork: International CE200
Engine: VT365
Rated Cap: 26
Two flasher circuits: Feed and Flasher
Hi,
Working thru my wiring to figure out what can be removed. Run into an interesting set of wires, they are labelled:
- Turn Signal - FEED
- Turn Signal Lights - Left
- Turn Signal Lights - Right
The feed seemed to carry 12V when contact is on. What I don't get is why there would be a permanent 12V for a turn signal?
Any thoughts?
Also, the circuit I identified (color and circuit number match) for turn right is not working. Turn left is OK, have not been able to locate a dedicated fuse for it, I assume it's behind a larger, shared fuse.
I really should have done a better job marking my wires before pulling all the lights
Bas
brijn is offline   Reply With Quote
Old 01-09-2020, 04:31 PM   #2
Year: 2005
Engine: VT365
Rated Cap: 26
Turns out that if you pair the wrong 9-pin plugs, your wires don't carry the expected signal. Who would have thought
I'll keep the two brake circuits for now until I really know I don't need them.
Bas
