Get a second battery of the RV, Deep Cycle, Type! Wire both your batteries to the isolator and stop worrying. But a Volt Gauge on the RV Battery with a momentary push button, when you wnat to know the remaining power, just push the button. If you REALLY want to protect the Bus Start Battery. When you are parked, use a 600 AMP shut-off or 'Kill' switch to completely separate the battery when not in use. 'No worries!' In case you don't know, wire the alternator output to the center isolator connection and the two batteries to one, each, of the other two connections.
