Old 09-09-2024, 02:26 PM   #1
Year: 2005
Chassis: All American RE
Engine: Cummins 8.3 ISC / Allison MD3060
VDO Tachometer Pinout
I'm about to go get my bus later this week.
It has a missing tach, I ordered a bluefire adapter and tested out the connectivity with my tablet/phone etc. and I'm about 80% sure it'll work on the bus as is. But just in case, I also purchased a replacement tachometer so I can solder it on when I'm there.
It's a 2005 blue bird A3RE, image of the dash is attached. I believe the OEM tach is a VDO 4000rpm, does anybody know what the pinout of that adapter is? and what that adapter even is?? I figure if I can purchase a male version of that adapter somewhere and splice some wires to the tach, it'll be a lot easier than trying to make something janky on the road.
kromboy is offline   Reply With Quote
Old 09-09-2024, 06:04 PM   #2
nikitis's Avatar
Rated Cap: 29
Bluebird tach part number for 2010 model is 00110409. it may work on the 2005 model. I'd call them and ask.
I don't think it changed much.
nikitis is online now   Reply With Quote
Old 09-09-2024, 06:46 PM   #3
Year: 2005
Thanks again for all the help, I will dig into that!
Old 09-09-2024, 07:41 PM   #4
ewo1's Avatar
grab your vin number and enter it into this BB vantage website. sometime you can get wiring diagrams here!
https://vantage.blue-bird.com/Portal/Vantage-Home.aspx
https://vantage.blue-bird.com/Portal...chematics.aspx
Old 09-09-2024, 09:29 PM   #5
Year: 2005
Oooh good call, I've been meaning to download all those diagrams and keep them. Just went ahead and downloaded them all and put'em on my laptop for reference!
I do see a diagram for panel assembly which shows how the dash panel connects, I'm looking to see basically what the each pins on that connector for the tach is, I'll keep looking, I have 46 diagrams to look through.
Old 09-10-2024, 08:57 PM   #6
sportyrick's Avatar
Chassis: F33695
I used a Stewart Warner tach and speedometer which only need power and a pulse from computer or speedometer and tachometer, they have dip switches on back for adjustments
