Will this battery support an inverter?
I had to recently replace my bus starter batteries and purchased two of the pictured batteries. The batteries that came with the bus were 700 cca and a friend told me to try and get as high cca so that I could run an inverter off of the batteries also. I didn't notice until after installation that the label mentioned, "not recommended for use with inverter".
Would there be a specific reason that would be the case or would it still be ok to hook up the two batteries for use, we're talking 2% of the year maye. The rest of the time will be on shore power.
Thank you for the advice!
