Wiring 50amp panel grounding question
Does this wiring setup look right? I have a 50amp inlet which are the 4 wires on the top. I will add all the fittings and stuff later but I wanted to check and see if I added the ground correctly? In my shop, my sub panel has the ground and neutral together. I read on here I needed to separate my ground and run a wire from this ground to the chassis.
