Looks good to me except you need a breaker on the AC circuit that feeds your charger/converter.
The charger/converter may all ready have fuses or a breaker on the DC output.
Thanks! I wasn't sure on that, and that helps answer my question.
One thought I had to save space was to split the input in the junction box as noted, and put both lines into the same panel (a 240V panel), one "side" for the breakers that power the AC circuits in the bus (to which I could also insert a transfer switch in-between it and the junction box for a later inverter), and the other "side" specifically for a breaker for the converter/charger. Is that feasible, or is that asking for trouble? I suspect this is not necessarily a good idea, because there would then be two neutrals in the box, which doesn't work.
I think I answered my question. I need one breaker panel for the bus AC circuits, and a second panel for the converter/charger's circuit breaker (unless there's a stand-alone breaker I can simply wire in-line).
As always, thanks for the thoughts, even if in this case, I may have answered my own question! hahaha
Chris
