Old 01-08-2023, 01:31 PM   #1
Chassis: Thomas Built MVP-ER
Engine: 5.9 Cummis Tan Block
Wiring issue with transmission
2001 Thomas built Cummings 5.9 with a MD3060 that is not shifting into gear. Staying in neutral. These are the codes that showed up on display.
#1. 45 - 22 G SOLENOID CIRCUIT OPEN
#2. 45 - 14 C SOLENOID CIRCUIT OPEN
#3. 22 - 14 ENGINE SPEED SENSOR
There's enough fluid and I also changed the shifter housing
No luck. Currently checking the harness for any corrosion and broken wires. Any one have a similar situation?
Prince408 is offline   Reply With Quote
