Originally Posted by mitchk
Side note. I also removed the coolant heater from the back of the bus. I used metal elbows to loop the tubing together so the old input and output for the heater are now just looped together. Is this normally how people get rid of the heaters. I did just realize that the heater probably dispelled a decent amount of heat from the coolant and now my coolant might be running too hot back to the engine but maybe this isn't a concern?
We kept the rear heater in our bus to for two reasons. 1) the back section is a workshop so can be closed off from the front. 2) in case we need to cool the engine a bit it can be used to dissipate the heat, like yo mentioned.
Using the elbows like you did is one way to bypass the heater. Does you bus have a cut-off valve inside the cockpit to open and close the coolant lines? I just calculated that every 25' of 1" coolant lines holds approximately 1 gallon of fluid. So if you have a full sized bus, you should have 2+ gallons of coolant sitting in those lines. We have opened the valve on hot days and watched the engine temp gauge drop by about 1/3.
I'd keep the lines simply for the extra coolant capacity.
