Old 05-02-2021, 01:52 PM   #1
DAVEHOLMAN's Avatar
Coachwork: Thomas Saf-T-Liner
Chassis: HDX with lift
Engine: Mercedes MBE 920
Rated Cap: 22
240v water heater on 120v
I need an electrical wizard to fact check this. I read that if you connect a 240v water heater element on 120v, you draw 1/4 the rated watts.
My goal would be to minimize invertersize. I can't find 120v water heaters with less that 1400watt elements. I'm thinking of a 3000watt, 240v. That should only draw 750watts from the inverter.
I understand my recycle time will increase, but are there any other negatives? Strain on the inverter or batteries, etc?
My alternative is turning everything else off when I want hot water.
DAVEHOLMAN is offline   Reply With Quote
Old 05-02-2021, 03:26 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
uh what?
regardless of your source ?
you will still only get 120 and never a true 230?
but i aint a sparky so i will shut up now.
just bumping this thread so the more knowledge able people will pick up the phone and help out
Old 05-02-2021, 04:22 PM   #3
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Most 240v WH draw power from two 120v conductors and no grounded conductor. Just a ground. Where do you intend connect the 120v neutral?
Check the manufacturers voltage ratings on the elements & thermostats, might be fine.
Great if your water is already prewarmed or solar heated.
Old 05-02-2021, 04:44 PM   #4
joeblack5's Avatar
Year: 98
Yes that will work fine.
For a 3000 watt /240 volt element will dissipate 750 watt at 110 volt.. recovery time will be about 4 times as long.
Still takes the same energy to heat a mass of water.
But you can get away with a smaller inverter and use it 4 times as long.
Normally the 240 vac is black and red . So at 120 volt you will now connect your white ( neutral) and black ( 120 vac line of your inverter to the black and red of the water heater.
Safety ground stays the same.
Good luck.
Johan
Old 05-02-2021, 05:04 PM   #5
DAVEHOLMAN's Avatar
Rated Cap: 22
Good luck.
Johan
Excellent. And other than the inverter being used longer, which I assume will marginally shorten its life, no danger (so long as it's wired correctly)...
Thank You!
