Hey Gang,
I have a brand-new Shurflo 182-200 accumulator tank. The supplied fittings leak like nobody's business no matter how tight or loose I tighten the things (followed instructions too). So the next step is finding new fittings. The Pentair website is useless for help by the way.
That said, the accumulator has two male NPSM 1/2" in/outlets. I cannot find NPSM anywhere, just NPT, FIP, MIP, XYZ, etc. I'm looking for a 1/2" female NPSM threaded fittings that have a barb on the other side to attach to a nylon reinforced hose. Actually went physically to a plumbing supply warehouse and they didn't have anything like it.
Looks like this, but FIP needs to be NPSM:
Here is my
tank for reference.
Short of throwing it out the window, has anyone else had this issue?
One more plumbing issue whilst on my rant here... I am looking also for a shower drain with an extended shank(?) pipe that will go through my 2 inch hole about another 2 inches. So the drain I have stops inside the hole, so there's no way to get a nut and/or clamp up in there. Cutting a larger hole would be extremely difficult in this case. So I'm just looking for a drain setup that has a 4-inch threaded shank. I thought back in the day there was an adapter that had threads on the outside and the inside, but haven't been able to locate one.
Anywho, thanks for any help you can toss a fella.
/rant
