Old 02-08-2020, 10:44 AM   #1
Sasquatters's Avatar
Coachwork: Thomas EF
Best outdoor RV shower.
Thanks to the people in this group we were able to find a very nice porcelain composting toilet which I doubt we would have been able to find on our own. We had been looking for months and months before we decided to post here and got the hell we were looking for.
The time has come again for more help! Weíve been looking for an outdoor RV shower that is nicer than the typical ones. Iíve searched and searched and found a few that are for boats that seem a bit nicer but are still cheap plastic.
This will be our only shower so it needs to last. I think a quick disconnect for the hose and shower head will be best since again, this will be our only shower and we donít want any freezing problems. Iím not sure if a retractable hose is the best route since it will likely be wet after use, and shoving that down into the wall will turn into a mold issue fast.
Open to ideas and excited to get this water ran. Itís really been holding us up.
Thanks!
Holly & Dustin
Our Blog | Facebook | Instagram
Sasquatters is offline   Reply With Quote
Old 02-08-2020, 11:00 AM   #2
Here’s a video with a great outdoor shower idea
https://m.youtube.com/watch?index=74...&v=WtZzRW96aB0
And this guy has an interesting take that maybe could be scaled up.
Maybe combined with a stair-shower?
Old 02-08-2020, 11:08 AM   #3
Also, what do you have in mind for a shower? Is it hooked up to a water heater? Does it have to be permanently installed?
One of those propane on demand water heaters could have a bracket where it could be hung when in use, with a hatch that has water supply and gas supply connections.
Old 02-08-2020, 11:28 AM   #4
I think the best bet for what you're looking for is to do a DIY shower using regular residential fixtures. Residential fixtures will ensure you get the quality that you're after. You'd need an enclosure, but it shouldn't be too much of a problem once you find one. You guys don't want the typical cheap RV stuff, and I can appreciate where you're coming from...I was looking for a nice outdoor shower system too, but I couldn't find anything that looked to be the quality that I wanted. I mean, we're really just talking about a mixing valve with a sprayer hose and shower head. All of which needs to be in a recessed box with a cover. Trick is to get a nice stainless steel box to mount in the side of the bus.
I wasn't able to find a fixture like you're looking for at the time I was searching.
Old 02-11-2020, 03:32 PM   #5
Danjo, thanks for the post, but those showers are way off the mark.
Old 02-11-2020, 03:34 PM   #6
I hear ya. I canít even find a RV shower box thatís not made of plastic. Itís kind of frustrating to have to literally design everything we want because the products available are junk. This project would be much easier if I were to come across a nice enclosure. Having a custom fabricated one is an option, but not preferred.
Old 02-13-2020, 09:07 PM   #7
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
I'm having the same issue. I settled and bought a plastic enclosure valve, but haven't put it in yet because it doesn't seem like it last long!?! I don't want to cut a hole in the side of my bus for junk! Let me know if you find anything!
As far as the shower curtain part... I'm planning on having something off of my back platform but haven't got that far...
Frochevy is offline   Reply With Quote
Old 02-14-2020, 09:58 AM   #8
naes14's Avatar
Engine: Dt 466e
Don't want to miss this.
naes14 is offline   Reply With Quote
Old 02-14-2020, 12:14 PM   #9
I'll mount a nozzle clamp on the outside of the window above the kitchen sink. The sink sprayer can pull out the window and mount in the clamp.
Old 02-21-2020, 03:38 AM   #10
Coachwork: Girardin
Chassis: E-350
I'm using the Eccotemp L5 tankless water heater as my shower. The heater itself is (soon to be) mounted in the bathroom, and the heater comes with its own shower head. When we shower, we'll just open the window and stick it outside.
TheArgobus is offline   Reply With Quote
Old 02-22-2020, 08:14 PM   #11
maddmaxx's Avatar
Year: 03?
Chassis: MicroBird
Engine: 7.3L powerstroke
If you want something super Heavy Duty. You may have to make your own. I once saw a video of a small off-grid hunting cabin that repurposed a military "M17a3 Decontaminating Apparatus". It's a low pressure, high temp all in one unit that pumps water from a stream, lake, or a holding tank.... Heats it from diesel or kerosene and pumps/pressurizes it (by gasoline engine run pump). Comes with a pick-up hose to a water source, standard spray wand to wash your rig, pickup tube to a cleaning solution if ever needed), and shower heads for up to ten people if you wanna have a shower party, lol.
Military has bunches of them they sell off for cheap w/ less than 5 hours on them.
I've often thought about using the parts of one in some kinda application for hot water supply... But maybe use an electric pump rather than the gas engine pump. Done up right... You could be the envy of Burning Man!
Seen them sell for between $25 - $750 depending on if all the extra add-on accessories are there. Which seems like a great deal seeing how our super efficient govt paid $23,121.00 a piece for them !!!!
Food for thought..... Plus you could fight off the CoVid 19 virus AND get a Heavy Duty lockbox to mount on your rig to boot
https://www.govplanet.com/for-sale/T...30-01-346-3122
https://www.ebay.com/i/283779249493?...26pg%3D2386202
maddmaxx is offline   Reply With Quote
Old 02-22-2020, 09:43 PM   #12
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
For those contemplating these auctions - don't forget the usual problems with auctions still apply...payment on time plus fees, pickup deadlines, delivery is usually impossible you have to pickup or have an equipment hauler pick it up and deliver it to you. It is not unusual for pickup/delivery costs to be much more than the winning bid cost.
Old 02-27-2020, 12:54 PM   #13
Anyone ever put an instant hot water heater on their bus?
Yardy is offline   Reply With Quote
Old 02-27-2020, 01:44 PM   #14
If you mean tankless water heaters, many of us have them. I have 3 on mine. One for the sink and shower and one for the heated flooring. I also have one on the back of the washing machine.
Old 02-28-2020, 11:08 AM   #15
Thanks! I appreciate the feedback. I guess that saves a ton of space correct?
Old 02-28-2020, 12:55 PM   #16
Chassis: Saf-T-Liner
Engine: MBE 906 Mercedes Benz Diesel
Sorry, but isn't that 4?
Beachvbguy is offline   Reply With Quote
Old 03-02-2020, 07:49 PM   #17
We have screens on all of our windows, and removing one of them to have a faucet hang out one of them in the middle of winter is not an option. Not to mention weíve tiled over the windows where the sink is. That government monstrosity also isnít an options since we would need to tow a short bus to accommodate it.
I believe sink/shower was one unit.
Iíve brainstormed what could be a great shower setup, but I need to find a metal box with a lock, similar to the RV shower boxes. If anyone can help that would be great. I donít even know what to search for. Everything that comes up is just the frame, and when I add ďmetalĒ to the search I start getting toolboxes.
