Old 08-11-2020, 10:26 PM   #1
Camplux Outdoor Only?
Hello,
I recently purchased a camplux tankless water heater.
Upon receiving the item and inspecting it, the instructions clearly state for outdoor use only. Yet, if mounted inside, must be properly ventilated.
Can I use this as my hot water heater for shower/sinks?
Any input is appreciated. Thanks.
dj2109 is offline   Reply With Quote
Old 08-12-2020, 02:55 AM   #3
The link you had in your post did not work, so I cut-n-pasted it and got to the Amazon listing.
https://www.amazon.com/dp/B01CJPU7ZQ..._Fc4mFbR8D8X16
... for those that like to click and go!
I liked what I read. It will put out a lot of heat! The description in the amazon listing also states that it can be installed indoors with proper ventilation to include a flue.
Old 08-12-2020, 08:22 AM   #4
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Oh wow, yeah this is a problem we had as well. You need two things: A way for fresh air to come in from the outside to be burned, and a way for the exhaust to exit to the outside. This can be hard to accomplish, and presents challenges in cold weather with freezing pipes/etc.
If you only install a flue, you will burn cabin air and that air will go outside. What will replace that air? Anywhere air can get in, air will flow in. Now lets say you had a fan mounted in the ceiling pulling hot air out- air will try to enter anywhere it can get in, including through your flue. How does that affect functionality/performance/safety?
This is also a problem when for instance, you're cleaning your black tank. With the fan on, you pull the vapors straight from the tank into the cabin, and the tank vent becomes an inlet. Be conscious of positive/negative air pressure in the cabin and how all of your ventilation / heat sources / openings will interact.
Ultimately we went with a tankless water heater designed for permanent RV use as it addresses those issues. Its definitely not perfect, though.
kazetsukai is offline   Reply With Quote
Old 08-12-2020, 10:11 AM   #5
Great advice
Ok I’m thinking I’ll have to upgrade to something like:
https://www.amazon.com/Girard-2GWHAM.../dp/B019BWN8E2
Old 08-12-2020, 10:20 AM   #6
kazetsukai's Avatar
Rated Cap: 76
Originally Posted by dj2109 View Post
Ok Iím thinking Iíll have to upgrade to something like:
We have that identical unit, I think.
Annoyingly we had to buy the front cover separately, seems like they fixed that.
Old 08-12-2020, 12:07 PM   #7
That look in her eyes says "I can't believe you lugged a tankless water heater up the side of a mountain, but I love you for it. Now go fetch the propane."
Old 08-12-2020, 12:10 PM   #8
bp1791-unleashed's Avatar
Chassis: Saf-T-Liner
Engine: CAT 3126E210
Rated Cap: 33,050 pounds
Attachment 47887
Just wait till he gets back with the propane and goes to hook up water to it...
bp1791-unleashed is offline   Reply With Quote
Old 08-12-2020, 12:24 PM   #9
kazetsukai's Avatar
Rated Cap: 76
What are you guys talking about all of that stuff is in the backpack its mounted to...
...right!?
Old 08-12-2020, 01:08 PM   #10
LOL!!! I’m not sure if they fixed the cover issue...
On amazon it says “people bought this together:” and shows the unit and cover
