Originally Posted by tguy1241
Since the toilet holds some liquid, have you thought about using one of the chemicals used in an outdoor swimming pool to keep it from freezing in the winter? I have no info on this myself, but if it works, the end result would be the same. Can’t hurt to Google what is in the pool anti-freeze chemicals. You might get lucky.
looks like its a glycol mixture.. this is also a new thing I never k ew existed.. pool antifreeze.. the people around me drain their pool down a couple feet and blow air through the plumbing to clear it all out.. and the pool may get an ice cap of a foot or so at max but being below ground they dont freeze solid...
ive been reading more and more where people who RV on and off in winter use RV antifreeze in their toilets without issue... at least their built in toilets.. several on irv2 (i always forget about them).. mentioned they keep their freshwater systems drained and carry bottled water / RV antifreeze mix to "flsuh" their toilet with.. it apparently doesnt react to urine or feces.. being my cassette toilet is not potable water i could run the antifreeze in it all winter it looks like...
since im not out long periods, my black tank is likely never going to be close to full.. thus far ive just emptied it into my home toilet without issue..
something I had forgotten about was absorbant "latrine" bags that apparently can be disposed of (at least with urine) in the trash? at least onbe on irv lines their toilet bowl with one of those when winter camping so they can keep their water systems winterized..
doesnt that bring up the whole conversation of whether its legal / ethical to toss poop or pee in the trash... an answer I still have zero idea of..
my thoughts of using a cassette toilet were to avoid such.. as small amounts i can simply flush.. larger fills i could go to an RV dumping station..
this is all pretty new to me.. but my main hang-up from using my Bus as more than a few-hour office have been a toilet.. showers i can handle at a truck stop, food i eat out all the itme anyway, sleeping - my air mattress is quite comfy.. , heat - my diesel heater rocks,. A/C - im going to install parked A/C and maybe more batteries so thats an on issue.. but the Loo has always been taboo
