Thanks everyone.
I've now learned quite a bit on heating a bus without propane. Although the cooktop still might have to be, but that's a discussion for another time.
1. I'll be using coolant [not water] and the built in heat exchanger inside the Kuuma 6 gal tank to heat up water while the bus is running.
2. When the bus is stationary and eng not running, I'll be using the diesel heater to do the same. Heat coolant to heat up the Kuuma and thus water.
3. The existing coolant refill reservoir will be used to add additional coolant so this issue has been answered.
My last question to clear up is on the direction of the coolant flows. As I understand it from reading, from joeblack5 " With the webasto the flow is opposite."
First some notes first on my bus. Its a 10 window rear engine Thomas, with a cat 7.2L which holds 4 gals of coolant.
At the engine, there is a coolant shut off valve, which prevents the flow of coolant to the bus interior. I usually have it off, so no flow to the interior. It will need to be OK or open anytime were heating water in the bus.
[My observation side-note. At 4 gals of coolant, this is allot of coolant to first heat up, in order to heat up some water, just an observation]
Im attaching a hand drawn flow of coolant and where the devices might be installed. The flows indicated are with the engine running.
As I understand it from joeblack5, with the engine OFF, that flow is reversed.
Engine running picture:
Pictured flow, coming out of the engine, while its RUNNING, were going into the Kuuma 6 gal tank and exchanging heat there w the hot water line, then we come out and we go into the diesel heater, which is OFF while the engine is running, we then go to the front of the bus and the heater core, and come out and go back towards the rear and the engine radiator. [i didnt label the Kuuma, it is the square that shows the exchange with H2O]
Engine not running. No picture. But the flow is reversed, starting at the diesel heater, we go to the Kuuma tank to exchange heat with the water, then go to the engine....
