Old 04-01-2017, 07:09 PM   #21
Year: 1994
Coachwork: Custom
Chassis: Bluebird
Engine: International straight six
Rated Cap: Unknown
Originally Posted by smilinbob View Post
I am thinking about cutting the floor and making a step down for the shower being that I have about 18 inches of free space under my bus and Im not a small feller. I talked to a few bus mechanics and they didnt see a problem with it and I was wondering if anyone else decided to go that route? Im trying to find different ways to drain it to the grey tank.
Thanks
i cut my floor and dropped a horse trough to sit down on the chassis my plumbing runs out the side to connect to whatever need be
Cabinbus is offline   Reply With Quote
Old 04-01-2017, 07:33 PM   #22
Year: 90
Chassis: safe-t-liner
Engine: cat re
Rated Cap: 79
The reason I decided not to drop my shower pan into the floor was mostly because the holding tank would then need to be lower than I want it. A person could put in a pump but then its just something else to malfunction and/or freeze up.
crawler is offline   Reply With Quote
Old 04-05-2017, 09:29 AM   #23
Year: 1994
Coachwork: Custom
Chassis: Bluebird
Rated Cap: Unknown
i plan on reusing my grey water so i just have the grey water gravity fed to an off bus location
Old 11-02-2017, 01:55 PM   #24
Can you post some pictures of your bathroom? I'm planning to install a horse trough, but I'm not sure how to do it.
Hernandez is offline   Reply With Quote
Old 11-02-2017, 05:21 PM   #25
Year: 1994
Coachwork: Custom
Chassis: Bluebird
Rated Cap: Unknown
Old 11-03-2017, 01:22 PM   #26
Thanks a lot CabinBus.
I really appreciate your pictures.
Old 11-04-2017, 01:28 AM   #27
Defjr333's Avatar
Chassis: Step Van
Engine: Prefer Diesel
Rated Cap: 14'-16' Step Van
Greywater pump?
https://www.amazon.com/dp/B00150196I...&pd_rd_w=8dHSL
Defjr333 is offline   Reply With Quote
Old 12-10-2019, 08:36 PM   #28
DrDanger's Avatar
Year: 2005
Pump options
I know this thread is a bit old, but some other people might be in the same boat I am: I lowered the shower pan but I have no idea what to do about a pump (or if I even need one).
The Sanishower pump suggested above would work I'm sure, but I am wondering if there is a less expensive solution. Any thoughts on just using this? Most shower heads are less than 2gpm.
DrDanger is offline   Reply With Quote
Old 12-10-2019, 10:56 PM   #29
I'm doing the same thing (tub projecting below the floor) but my plan is to have the gray water tank slung low so that the tub drains into it naturally, so no pump would be needed. This will put the bottom of the gray water tank near the bottom of the skirt; some people might want more clearance than that, but I don't plan on any off-roading.
Old 04-14-2020, 03:31 PM   #30
i'm following this. i had this exact idea because my hubby is 6 ft tall and i'd like for him to be able to shower standing up. I'd also love to be able to take a bath so a horse trough has definitely been on my "watching for" list.
AvoCadOH_family is offline   Reply With Quote
Old 04-14-2020, 03:55 PM   #31
I'm doing the same thing but with this step tub: https://www.campingworld.com/sit-in-...ite-68807.html projecting below the floor. If you can weld and have access to some reasonably-priced scrap metal, it's pretty easy and cheap to do on a school bus. One caveat is that to have an all-gravity-fed drainage system into a gray water tank, your clearance is fairly tight. I don't want my gray tank to be sticking below the side skirt, so I'm restricted to a flat 9" tank and a hepvo valve, which is a horizontal alternative to a p-trap.
However, you can also install a system where the dropped shower drains into a small temporary tank, from where it's pumped uphill into a higher-mounted gray tank. I didn't opt for this because I want my setup to be as simple and cheap as possible.
Edit: just realized I said basically the same thing two posts earlier. Ah well ...
Old 10-18-2022, 11:00 PM   #32
Engine: Dt466e
I both dropped the shower (wet toilet combo) through the floor and used a small; 6 gallon grey water tank with a lift pump to the regular grey tank. The pump is accessible through the original filler/pour spout and is operated by a switch in the shower stall. The important thing is to use a "P" trap for odor and a screen in the drain for hair. So far no problems. Because my bus is so short I also cut a hole in the roof for more headroom. I used 2" of foam to insulate under the floor and in the roof. As can be seen in the final picture, the front wall of the bath made a perfect place to hang the TV/DVD thingy.
WOW!!! I hope to do this as well.
You are truly inspirational!
Thanks for sharing.
Any tips, tricks?
!eslie.brewer.me is offline   Reply With Quote
Old 10-19-2022, 09:15 PM   #33
When I saw that I felt like I was in a 747 for a second. Very nice work there.
Veloc is offline   Reply With Quote
grey tank, shower, step down
