Hello friends! I was hoping that I could get some feedback and a double check over my logical plumbing diagram.
Hopefully the little notes added in make sense. I'm not specifically trying to make sure I have every fitting or stuff here, I just want to make sure that logically everything makes sense and I have all the "bigger" stuff accounted for.
Note, I won't have a flushable toilet so no need for a black tank.
The two water tanks will be on either side of the bus, so I think weight distribution there will be fine. I have two gray tanks mounted under the bus. I figure I'll just route output into one, and that'll naturally fill the second one. Hope that makes sense.
I already have a working water pump that I was able to pull out of an old RV for $10, which was nice. No idea what to look for though in terms of an accumulator, would love any suggestions there.
I think that is about it. Thank you!
