Originally Posted by kellin
Hey guys,
Not sure if anyone else here has run into this issue with their ClassACustoms freshwater tank. The tank they sent me has 4 openings, two 1/2" openings (for air vent and line to water pump), and two 1.5" openings (for water fill and water drain). I would like to be able to drain the tank with a hose, but I can't seem to find a fitting that reduces from 1.5" to a 1/2" fitting for my pex line to go into. Does anyone have a suggestion for what fitting to use or have any experience draining another way? I am looking to run the drain line out from the water tank to the rear emergency exit.
Thanks a lot.
Sounds like you're already using the half inch opening for supply, so the only thing you have left is the inch and a half opening, correct?
There's no single fitting that does that to my knowledge, but if you want to completely drain the tank consider an inch and a half plug with a half inch NPT opening at the bottom of the plug.
