Thanks. The plan is to build the tanks so they can be slid in and rest on the ribs with fastening only used to prevent sliding and movement, the tanks being press-fit. If I have to use thru-rods or straps for additional support, it's not worth it.
If the existing stamped s-channels can't be used to support tanks long-term, even when spreading the load across multiple s-channels - I'm going to have to look for junkyard I-beam ribs / cross members like what's found on semi-trailers, and weld them to the frame. If I am having to use rods or straps I might as well go with Iceni John's method.
Just looked at ATL potable water bladders and the prices make it a no-go (
ATL Potable Drinking Water Bladder Tanks - NSF/ANSI-61 Compliant), was expecting in the 100-200 dollar range per bladder. Maybe someone knows where to find bladders meant to go inside reinforced compartments ("bag-in-box")? My concern with a bladder is chafing and pinhole punctures, even after I smooth, deburr, despald and then tractor paint the interior surface and corners. How close / far are we to exhausting our leads?
Remember, this idea has to compete with Iceni John's method, and -if- I am going to need to add ribs either way for support, it shouldn't be a factor in the competition. I am seriously considering extending my insulated envelope to include all the space to the bottom of the skirting, including the driveshaft between the frame. Aside from keeping dust out, I don't have to insulate tanks and lines individually. Eventually I would add a belly frame using hardened, thick-gauge 2" steel square tube for total protection from gravel and shale (I plan on driving the Dalton several times).
Being a bus that spent it's life in and around Salem, OR - the undercarriage is full of fine sediments, and the driveshaft linkages have splattered mud that's might as well be shotcrete. I tried to get this off with Now that it's all dried out, it's going to be quite a dust show when I drive it to Santa Cruz later this year.
