Old 04-12-2020, 11:31 AM   #1
Fresh Water Tank Question / Concerns
It has been a while since I posted anything, but as of this day, this second, there is a good chance unless all goes sideways that I am going to be getting a bus tomorrow. With that in mind, it sort of got real real quick. You can imagine I have been going through and getting updated prices on various pieces and parts that I am going to need for the build. I started with the water tanks. Now, like everyone, I am about saving money, but there comes a point that you sacrifice quality / piece of mind / safety for price. I am looking at putting 200 gallons of fresh water in the bus. This means I am going to be connecting 2 - 100 gallon tanks together. Most water tanks I see priced between $300-600 for one 100 gallon tank, until I came across this one
My question is has anybody used or purchased this tank before? And what is the quality?
My second question, it appears that this tank only has 1 inlet. Recommendations for connecting two of these tanks together? Along with installing a water fill / water level meter?
or
Would you recommend that I go with a tank that has multiple threaded inlets installed for the $500-600?
imkzrudob is offline   Reply With Quote
Old 04-12-2020, 04:49 PM   #2
That's the exact tank we got, from the same place. We picked it up in person to save any shipping costs. It's got 3 threaded outlets and one inlet. It's decent quality, though I have nothing else to compare it to. We boxed ours in with lumber to keep it as stable as possible. I think you could tie them together at one of the outlets, or with a common tee on the inlet.
We got a SeeLevel II tank monitor for fresh and grey tanks. The sensor just sticks to the outside of the tank, no problems there.
Old 04-12-2020, 07:01 PM   #3
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I wanted a 100ga tank but couldn't find one at that price. Looks like a good deal.
You could look into Uniseal? I just discovered it this week. My grey water is a 30 gallon barrel, and I was unsure how to connect a drain to it. Uniseal is meant specifically for that application, but it should work for you maybe also.
JDSquared is offline   Reply With Quote
Old 04-12-2020, 07:22 PM   #4
@Drew
Thank you for your reply. Sometimes too cheap means loss of quality. I didn't want to end up with a flooded bus.
@JDSquared
Thank you for that info. It is my plans to have 200 gallons fresh water, 100 gallons grey water and 5 gallons to be a urine collector stored under the bus.
On a different topic, the reason I am separating my grey water from the urine is because I am also investigating the practicality of filtering the shower and sink grey water to be re-used for showers, which would mean I would have a 50 gallon treated grey tank just for showers. I'm not sure of the feasibility of that...just something I am investigating.
Old 04-12-2020, 07:26 PM   #5
Yeah, I hear ya. That's why we boxed the tank in with 2x12 lumber. The plastic didn't look flimsy, but having 800lbs of water sloshing around made me a little nervous about the strength of the tank itself. Better safe than sorry.
