Old 02-15-2020, 05:58 PM   #1
Garden sprayer and tank as water tank?
Has anyone ever used one of those 25-50 gallon garden sprayer tanks on wheels as a source for holding water?
BusZen2003 is offline   Reply With Quote
Old 02-15-2020, 06:14 PM   #2
Chassis: 25' Bluebird
Engine: T444
Rated Cap: GVWR 27,500
nope
For freshwater, you need a food grade tank, period.
Don't cut corners on this one.
You don't want to slowly poison yourself.
Think of all the money you're saving by building your own skoolie rather than buying an RV. Don't be so cheap that you end up hurting yourself and your friends and family. Just get a food grade tank They're not that expensive.
I got this one and it was well worth the $118 to make sure we have safe drinking water:
https://www.amazon.com/Holding-conce.../dp/B007MSLP7A
That one was great because it's rectangular and fit very well under the bus. In another build, I used a food grade 50-gal round blue barrel tank, worked just fine. Cost something like $15-25 locally, used.
gabrielah77 is offline   Reply With Quote
holding water, water supply
