Old 07-22-2020, 01:09 PM   #1
Chassis: FE 3900
How to clean your urine line?
I have a Seperette composting toilet, with a urine diverter that has a 1/2” I.d. hose, which goes to the grey water tank. The system is about 3 years old and the urine line is having drainage problems. As I clean it out there seems to be brownish build-up that I assume is calcium and mineral deposits from the urine over time.
Besides replacing the line, what’s the best way to clean this out of the line?
Going forward, how do I keep the line clean from future build up?
Your advice would be appreciated.
Daledorm is offline   Reply With Quote
Old 07-26-2020, 12:19 PM   #2
Chassis: FE 3900
What I did...
I disconnected the line from the grey tank. Cleaned out the stuff that was blocking in pipe there. Then I flushed the line with 5 gallons of water by pouring down the pee hole. Then I Pinched off the line and put in vinegar and let sit for 30 minutes then flushed the line again.
I kept getting small chunks of brown crystals so I kept flushing. Finally, I put in baking soda and vinegar into the line and let sit and flushed the line again.
Seems to be running again.
Let me any other suggestions you have tried.
Old 08-01-2020, 11:35 PM   #3
DreamWeaverBus's Avatar
Engine: Cummins 5.9 Allison AT545
Rated Cap: 71
I actually plan on running my drain line from the bathroom sink to the urine diverter pipe, so that when I wash my hands, the soapy water runs through and cleans the pipe. Gonna be a lot of angles in that line lol...
My hope is that doing this will prevent the urine line from getting very nasty in the first place. Time will tell.
DreamWeaverBus is offline   Reply With Quote
composting, diverter, plumbing, toilet, urine
