Bamabus
A 1998 tc2000 would be Cummins 5.9 - most likely mechanical injection.
All hoses for heaters run along the left wall. Should be a front heater, booster pump halfway back, then the rear heater. If you have the tc2000 owners manual, there is a diagram at the back part of the manual.
Water shut off valve is under the front right side, near the middle. Your feet will stick out from the bumper. Mine is a 90 degree ball valve.
The second valve, lift up the engine cover, the valve is just below floor level at the left rear corner of the opening.
The entire run of hoses and booster pump are covered with metal shields. Uncover all the hoses and check for leaks. The owners manual says to check/ tighten hose clamps once a year.
William
