Originally Posted by jmiraglia
I originally had an AMOLED touchscreen for my touch interface, but it was fragile and broke It was a beautiful looking display though. If you haven't already, checkout superhouse.tv, he makes/sells PCBs for momentary push buttons with RJ45 connectors already soldered on. It makes for some pretty clean wiring (even shielded if you need)
Yeah I saw those, very clean. I'd have loved to just have ran ethernet like that. Very slick.
I just used 4-conductor 18 gauge (two leads for light, two for signal). Goes into a DIN mount screw terminal. Similar to the ones on your breadboard, that's also very slick. Gotta get me one of those...
The whole automation panel takes up lots of space. Relays for control tap from a fuse-per-string of lights, ended up needing three fuse blocks to support them all.
Current UI leaves a lot to be desired, I'm getting my logging together right now, then I'll focus on that a bit. The MPPT data got a liiiiiittle too big (~36GB) after a couple months of gathering for the technology I chose, so I have to use a beefier database.
Yeah, your top down view is pretty close to what I'm going for. Maybe with a C-frame or L-frame around it for other stuff.
OP, I'm going to copy some of your interrupt code I think. And some of the bits for doing the flow rate calculations.
