Originally Posted by tmcclawfirm
I’ve got a male barbed 1/2” NPT outlet on the freshwater tank that I clamp 1/2” ID reinforced vinyl tubing to. Then I want to put a ball valve before the pump, but it’s got male PEX fittings (also 1/2”).
Ok, ditch the vinyl tubing, that not a good spot for that. The piping between the outlet from the tank and the inlet for the pump will see slightly negative pressure (suction) when the pump is running. You want something that is less likely to collapse. You can just put a 1/2” ips ball valve right on the tank outlet, or just use a 1/2” female pex adapter. Vinyl tubing has no place on the pressure side of a plumbing system. You should only use it for the tank fill line.
