Originally Posted by Danjo
The only thing thats challenging with iron pipe is getting lengths and angles right. It can be a bit frustrating in tight spaces to get that right. One thing that works well is to trial-fit pipe from the appliance backwards. Though you’ll ultimately need to undo it and reassemble from one end to the other, it helps you figure out what you need
sorry i am late to this discussion.
i do steel pipe for a living so maybe this piece of advice will help someone out.
maybe a pain in the butt in a skoolie and am getting ready to do a shortie?
my big bus was simple.
anyway.
the easiest way to measure a cut for steel pipe.
install your beginning fitting tight and then hold your elbow where you want it to turn down, then measure face to face of each fitting then add 1-1/4" to that and that is your cut and thread length.
it works for everything up to 2" pipe after that its a little different as you get bigger.
the 1-1/4" is because the threads go into the fitting 5/8" on either end.
if you have a big box store cut and thread them for you then on his first thread if he doesnt check the threads by running a fitting on it by hand then ask him to.
i usually use the machine and install it by hand until i cant hold it and if the threads are correct then it should be 3 full turns off before a pipe wrench is ever used.
if its more then the threads are to deep and if its less then the threads are not deep enough.
2-1/2 to 3-1/2 should be your target point.
anything more than 3-1/2 turns on the fitting by hand you tend to run a chance of cracking the fitting once you put pipe wrenches on them. especially big box store chinese stuff is split casted fitting.
i have an LP gasmans hand book if you want me to look up your specific line length and combined BTU?
stove,oven,heater total and where each one is inline and in some instances the amount of elbows adds to the count. for instance(example) each hard elbow could add 1' of line length.
not trying to make it sound diffucult but we only want you to do this once.
60,000 BTU sounds like alot on a 3/8" line to me and if nothing else was connected or was connected and not being used at the same time the 1/2" still sounds small for a low pressure system.
a high pressure system maybe a low pressure system???
