Old 05-15-2021, 03:14 AM   #1
Recycling mini split water
Anyone have experience capturing water from a mini split and filtering it for use in their conversions?
I'm very interest in this and other forms of water use reduction. Like recirculating showers
There aren't many details on it, but the creator of this conversion claims to collect water from the air. Sounds like either a dehumidifier or mini split capture.
https://youtu.be/63VaJIXP874?t=1718
frostyllama is offline   Reply With Quote
Old 05-15-2021, 09:03 AM   #2
joeblack5's Avatar
Year: 98
It has been done.
I use condense water out of the fridge to water my lead acid batteries. To condense water takes a lot of energy and in the desert the humidity is pretty low already..recycling water as much as you can is a smart thing to do.
Johan
Old 05-15-2021, 09:21 AM   #3
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 30,000 lbs
Well, thatís how a dehumidifier works.
At 80 degrees F and 100% relative humidity one pound of holds .00223 lbs of water.
Say you remove 20% of that. 0.000223 lbs/cf. Say your bus is 5000 cf. Make it a pound of condensate.
Say that you condition your busí air volume five times per 24h. Gives you 5 lbs of condensate.
So sure. Itís possible. Is it worth it? Not for me. Iím all for recovery and efficiency, but this is a lot of trouble for little gain. Unless you are in, say Florida, where it is hot and humid a lot, itís also a very unreliable source of water. Do you capture rain water? That may be lower hanging fruit in many parts of the country.
And then we are not even talking about how much power it takes to run a dehumidifier. Sure, you run A/C for comfort, cost being what it is, but to pull water from the air I would not do it.
Bert06840 is offline   Reply With Quote
Old 05-15-2021, 09:31 AM   #4
I’m recycling water at home. Catch the cold shower water. Use it to water the plants. Catch the shower water, use it to flush the toilet. I guess I’m at about 10 gallons a day.
Sorry don’t mean to skew your condensate question.
Joe, that’s a great idea since the water should be as distilled.
I wish I would have worked on recycling strategy on my bus build. There’s still always conservation.
Old 05-15-2021, 10:03 AM   #5
joeblack5's Avatar
Year: 98
Danjo, that is very impressive. We set our house up to recycle water but I have not completed the project. Used to catch the shower water to let it allow to cool down inside and reuse the heat..now we have evacuated tube solar and the energy is less of a concern...we do catch all the rainwater on our roofs and fill the 6000 gallon pond and another 1000 gallon tank . Currently only used for watering the garden...gravity feed u derground hose.. put pipes to use it as shower and wash water.. our tap water is very hard so it would be worth it from that perspective.
Johan
Old 05-15-2021, 10:50 AM   #6
Johan
Iíd love to do that with a house. Iím in an apartment now and Iím doing it with buckets
Old 05-15-2021, 02:45 PM   #7
Originally Posted by Bert06840 View Post
Well, that’s how a dehumidifier works.
Say that you condition your bus’ air volume five times per 24h. Gives you 5 lbs of condensate.
So sure. It’s possible. Is it worth it? Not for me. I’m all for recovery and efficiency, but this is a lot of trouble for little gain. Unless you are in, say Florida, where it is hot and humid a lot, it’s also a very unreliable source of water. Do you capture rain water? That may be lower hanging fruit in many parts of the country.
The builder of the video I posted claimed to pull 8 gallons of water a day in good conditions, presumably just from his cruise n comfort. He could have extra hardware, trying keep the IP locked down.
Ive got a mini split on order for my short bus conversion. 1.4kw solar on the roof 2x 3000w inverters and a 14kwh diy battery pack for storage. Also plan on some alternator charging. Totally electric utilities. System should support all day a/c in sunny weather.
Power shouldn't be a problem, and the mini split will be running most of the time anyway. Just need a filtration system for it, don't mind experimenting.
The water catchment is a great idea but I'm not sure how feasible it is with a 15 ft roof covered in solar panels. Nice thing about the condenser is you don't have to wait for rain, just need relative humidity.
Old 05-15-2021, 09:30 PM   #8
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Sure, why not give it a try?
People that are super protective of their IP usually do so because they donít have anything that could stand the scrutiny. In order to be worth anything, it has to be non obvious. Otherwise you canít get it patented nor can you keep it a trade secret. Iím not hitting on that guy specifically, this is just a general statement.
Whatever he does, itís not going to violate the laws of thermodynamics.
As a reference... a commercial dehumidifier, a device specifically optimized for this task only, extracts between, say, 1 and maybe 2 liters for each kWh consumed. Thereís an energy star label for it and all. Letís say itís 1 for easy calculation.
8 gallons, letís call it 30 liters. It would take him 30kWh.
You have 1.2kW in solar. Letís assume youíre not tilting it or anything and say it produces 6kWh a day on average. So if you would park next to a swamp and pump ALL of that electric power in the most efficient dehumidifier on the market with an EEV of 2, you got almost a dozen liters. Thereís not going to be a lot of cooling to be had, but half a bucket IS within reach!
If you were to just collect condensate, a liter here, a liter there: why not? I donít think the condensor produces water with more particulates/microorganisms/toxins in it than what you would pump from a creek, so the filtering is probably the same!
Old 05-15-2021, 09:35 PM   #9
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
I just re-read your post, and saw you have 1400W of PV. Thatís an almighty amount. Where do you fit that? How big is your bus?
Also 14kWh of battery. Mine is 15kWh (maybe 13kWh net) and I thought I was crazy.
Old 05-16-2021, 12:36 AM   #10
Rock-N-Ruth's Avatar
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
We didn't even route the drain from our mini split. We just stuck the drain in a half gallon jug. We got about an ounce and a half last year. Desert livin is a trip.
Rock-N-Ruth is offline   Reply With Quote
Old 05-16-2021, 01:53 AM   #11
I just re-read your post, and saw you have 1400W of PV. That’s an almighty amount. Where do you fit that? How big is your bus?
It was a tight fit. It's 4x350 panels. Tried to get a group buy in for 600 watt panels. Hopefully they'll be available domestically soon.
I appreciate the hard numbers, it sounds like it was an exaggeration
Good to know
Edit: bus is 21ft bumper to bumper roof is about 15ft
Old 05-16-2021, 03:04 AM   #12
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
Ruth and I have 12 327W panels on the roof for about 3900W charging 6 220AH Lifep04 batteries. We never plug in or start the generator. Not even when it has been cloudy for days.
Old 05-16-2021, 09:33 AM   #13
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Wow. Thatís rather full
Whatís your output? Peak/average?
The 400W system on our van CAN do 400W. I have a screen shot!
Old 05-16-2021, 09:37 AM   #14
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
But as said elsewhere, a kWh a day during summer (in the Northeast, this was in Maine and Vermont) is a good number for this 400W system. So Iím counting on 2.5 times peak capacity, in my case 2.9kW (allegedly), so Iím assuming 7kWh or thereabouts as daily summer yield.
Also, the one day to the next variation can easily be 400%.
Old 05-16-2021, 10:14 AM   #15
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
Attachment 57497
We are capable of more than the rated 3.9k. Often after a long night of hard drain on our huge battery bank we will produce as much as 4.2k by noon even on cloudy days the batteries are topped and we will be making about 900w to cover the draw from the mini split.
Old 05-20-2021, 06:34 PM   #16
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Your a/c just removed that water from the air and the air wants it back. LOL
