Old 04-22-2024, 09:18 AM   #1
Separett toilet venting
Hey everyone,
Anyone using a She Separett villa? I have seen lots of people are using natures head toilets or air head toilets. I have seen a few pictures of Separett’s on Pinterest but there are no details of how people are venting them. We are looking at getting one but I haven’t found a great roof top vent for a 3 inch pipe and I do not want to do a residential style candy cane. The best idea I have had is to y the 3 inch into two inch and a half outlets then use two Rv style swivel vents. Any thoughts?
Tdi-337 is offline   Reply With Quote
Old 04-22-2024, 01:24 PM   #2
sportyrick's Avatar
Chassis: F33695
Is there a problem with rain or snow getting into the works? If not then here is how I did mine, I welded a piece of steel tubing on my roof and stuck my vent stack through it and added a boot or hose to them both with hose clamps. Who cares if a little rain adds to my black water tank.
Old 04-22-2024, 10:19 PM   #3
Ya I will be a little concerned about moisture into the toilet since it is a type of composting toilet. But I have thought of something similar to what you said.
Old 04-23-2024, 09:20 AM   #4
Chassis: Ford E450
Engine: V10 Gas
The area of two 2" pipes is slightly less than a 3" pipe. I like the idea, but if you do get one I recommend you test it first with that configuration. It's an incinerator toilet with a fair share of sensors that may not take kindly to alternative venting methods.
Old 04-23-2024, 12:23 PM   #5
sportyrick's Avatar
Chassis: F33695
A vent stack is the only thing on my roof and it's up there pretty securely and with a short tube welded to the roof it won't leak into roof structure unless boot gets torn off and that's not likely.
