Old 06-11-2021, 09:49 AM   #1
Rated Cap: 42
Shower wall backer recommendations
Hey guys
Looking for recommendations for backer board in a shower. I used Kerdi board in my build behind ceramic tile, but I'm doing a build for a client and she has a limited budget.
Cement board seems risky with all the movement in the bus.
I also don't know yet whether she is going to go with ceramic or vinyl/pvc sheets or something else.
What have you used that works well?
Thanks!
ghodges is offline   Reply With Quote
Old 06-11-2021, 10:19 AM   #2
We like to use James Hardie's HardieBacker with fiber tape on the seams and Red Guard to seal those seams, and we've never had an issue. HardieBacker is a cement board, but it's not as heavy or difficult to work with as the old stuff I started with (in homes) which was cement and styrofoam with a layer of mesh on both sides. HardieBacker is easier to work with and the Red Guard/fiber tape seems to seal really well.
Old 06-11-2021, 10:34 AM   #3
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
On a limited budget, FRP panels. This is the route we are going this weekend and from what I've seen, should work out nicely. Waterproof.. relatively easy to seal up and work with.
Old 06-11-2021, 11:48 AM   #4
I used the foamcore backer. Hydro-Blok. Not cheap. If I were to do FRP I’d use plywood probably
Old 06-11-2021, 10:32 PM   #5
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
I've watched this guy in preparation for how I might do my shower area.
In this particular video, he's linking to what he considers the best video on using RedGard.
It pretty well speaks to what Ross was suggesting.
Hope it helps.
Steve
Old 06-11-2021, 10:37 PM   #6
Originally Posted by Simplicity View Post
Hope it helps.
It definitely helps with my spelling! I just bought another gallon pail of it about 2 weeks ago and didn't remember it's spelled RedGard and not Red Guard. It's about $50/gallon, but that goes a long way and I've not found another product which works as well. Semco makes something I see advertised often, but I've got no reason to switch.
Old 06-13-2021, 10:39 AM   #7
Rated Cap: 42
Thanks guys. I really appreciate the input
