Old 12-16-2019, 10:48 AM   #1
Year: none
Coachwork: none yet
Chassis: none yet
Source of water? Solar powered dehumidifier
Just had a thought for boondocking.... buy a home dehumidifier, putting it outside, plug it into your bus's 120 volt outlet, and having the water go into bottle or the fresh water tank.
I read that a 4500 sq. ft. unit would remove 50 pints (>6 gallons) per day from indoors.
Not sure how much difference interior humidity in house would be from in a bus or from outside but a ~$210 4500 sq. ft dehumidifier feeding into a Royal Berkey water filter..... Uses 4.7 amps, 120 volts
Would this be a good addition to making your water last longer between fill ups at a campground?
Anyone done this?
MrJDL is offline   Reply With Quote
Old 12-16-2019, 11:29 AM   #2
Coachwork: Blue-Bird
Chassis: TC RE 3408
I think your idea will work just fine, but whether or not it's economically viable is a totally different question.
gs1949 is offline   Reply With Quote
