Old 11-05-2023, 05:58 PM   #1
SW6D water heater install wiring/ lighting issue
Hello! Water Heater trouble shooting!
We have a new Suburban SW6D water heater installed in our skoolie and have never gotten it to light. the ignitor sparks but it seems like no propane is getting to it (our propane system works great for our stove/range and it doesnt seem to be a leak as our leak alarm doesn't go off either when trying to light the water heater). So my guess is its something electrical not opening the solenoids to the water heater.
WE did just try replacing the solenoid switches as I read thats a common problem, but that didn't change anything.
Attached are some pictures of out wiring, which is where I think we went wrong, but maybe someone has some knowledge on it
Sshiluk is offline   Reply With Quote
Old 11-05-2023, 06:09 PM   #2
Do you have the toggle switch for it?
I have the same water heater. It works great.
First thing I’d do is remove power from the unit, go hit the reset switch that’s under a rubber boot on the front of the tank then turn it back on.
I recall the wiring diagram is confusing. Let me pull up some info and see if I can help
Old 11-05-2023, 06:47 PM   #3
I didn’t dig down to the circuit board, but I looked at what I did and I actually used some color coding tape on the wiring that I did.
Red goes to the toggle switch. The other side of that switch goes to positive.
I have Blue and a negative wire both going to the LED. I think they’re reversed That light has never worked and that explains why.
The white and green shown in the photo are tied together at the negative side of the fuse block.
So mine works, but I believe the LED is wired in reverse which would explain why the LED doesn’t light.
Old 11-05-2023, 06:48 PM   #4
We have it hooked up to a normal 12v toggle switch for power(one of these three our lights are on the other 2):
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And the propane on/off connected to the solenoid on the propane tank is attached to:
Do you think that might be the issue?
Old 11-05-2023, 06:51 PM   #5
Should we buy this switch instead and see if it works, or do you think the current switches are okay and its something else?
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 11-05-2023, 06:56 PM   #6
How did you switch the gas valve? I didn’t do that.
Old 11-05-2023, 07:00 PM   #7
Just to be clear in the photo:
Green: Neg to the fuse block.
Blue: ? Straight through I guess
Red: Pos to the Junction box
Black: Pos at the fuse block
White: Neg at the fuse block
Old 11-05-2023, 07:38 PM   #8
Are you saying that you have an electronic solenoid that turns on the gas at the tank?
I think this might be the problem. How is this wired? I’m just letting the control board operate the solenoid on the water heater.
If your gas is working for other appliances then maybe it’s not the problem.
Old 11-05-2023, 08:11 PM   #9
Rated Cap: 37,400 lbs GVWR
I'm extremely wary of Chinese switches. Many of the Chinese switches I've ever bought have failed, some almost immediately, some after a few years, but their failure rate is completely unacceptable to me. I've now replaced every Chinese switch in my bus with Carling or Blue Sea switches, with zero resultant failures.
And PLEASE don't buy from Amazon. Screw Jeff Bezos!
Old 11-05-2023, 09:09 PM   #10
Thank you. I deleted my Amazon account a dozen years ago and never looked back
Old 11-09-2023, 02:56 PM   #11
Yeah I have a master solenoid outside the bus at the tank (for extra safety, so when propane isn't in use we can shut it off outside of the bus without having to crawl under and manually shut it off). It hasn't effected out other propane appliance, it works fine, so I dont think thats the issue
Old 11-09-2023, 03:26 PM   #12
Can you describe how it’s wired?
electrical, propane, propane appliances, sw6d, water heater
