Old 05-09-2021, 11:45 AM   #1
Water pump leak
My water pump keeps making constant obnoxious sounds when it is turned on. I read in the manual online it could be from a leak but I don’t see water leaking anywhere. What should I check to verify if this is the problem or not? And if it is what would I need to do to fix it? This is the first time I’ve had issues and not sure what to do. Here is a pic of my setup sorry for the sideways view. Thanks for any and all help
navigationnowhere94 is offline   Reply With Quote
Old 05-09-2021, 12:56 PM   #2
Engine: C7 Cat
Do you have an accumulator tank in your system? Click image for larger version
Oscar1 is offline   Reply With Quote
Old 05-09-2021, 01:17 PM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Oscar's question is right on track. I'd also add...do you have a check valve in the system? In the first diagram Oscar posted, I'd move the check valve to a position right before the accumulator tank. It's possible that your pump pressurizes the lines, then water leaks back through the pump...which then "growls" at low speed to pressurize the lines again. Essentially, this is a leak that you cannot see. The accumulator tank and a check valve should resolve all your issues.
rossvtaylor is online now   Reply With Quote
Old 05-09-2021, 07:26 PM   #4
Ours made obnoxious sounds that got worse over time, which ultimately led to it not shutting off unless we switched it off manually. The problem was a worn out pressure switch. It's at the top of your pump and the red wires are connected to it. A new one cost 13 bucks and took like 5 minutes to replace. Not sure what obnoxious sounds your pump is making, but from what I gather those switches are a normal wear item.
Old 05-09-2021, 07:45 PM   #5
I don’t know if that would be the issue with mine it’s only a month old :/ check out this video I posted yesterday, this is what my pump is doing
https://www.reddit.com/r/skoolies/co...tm_name=iossmf
Old 05-09-2021, 07:48 PM   #6
I do not have that, no. I hired someone to do all the plumbing and electric work and that was not installed
Old 05-09-2021, 11:06 PM   #7
FWIW, seems like all our RVs over the years had the water pump kick on intermittently for a few seconds. Maybe temperature changes.
Maybe your pump let’s a little backflow.
