Water Pump Troubleshooting
Hi all,
Beating my head against the wall on this one...need help.
- Installed 12v Shurflo Water Pump in my conversion. Worked really well for months.
- Drained my tank and couldn't get it back to pulling water from the tank after refilling it. Checked on YouTube for some help. Nothing. Hired a plumber. Nothing. Replaced the water pump and tried some of the same tricks. Eventually, got it working again. EXCEPT, where before the pump would kick on and turn off automatically when I would run the sink or shower, now I had to manually work the power switch. AND...flow was not quite as strong as before, but it was functioning.
- A while later, I needed to sanitize my freshwater tank and drained it again, then refilled it.
- Could not get pump to pull water after refilling. Tried same tricks as last time, including backfilling, priming, put my old pump back in, nothing. Hired another plumber. No dice.
- Wtf?
Thanks, ya'll! Any help or advice appreciated.
