Old 02-14-2020, 12:52 PM   #1
Weight distribution
So, I have an international 3000 series short bus. 25 ft bumper to bumper on a full sized chassis. I’m looking at water tank placement. I have the last 30 inches devoted to a storage “garage” and my bed in front of that. I’m looking at putting two 30 gallon fresh tanks inside, under the bed, and two more 30 gallons grey tanks under the bus. The easier place to put the grey tanks is on either side behind the wheels, and I’d like to put the fresh tanks behind the wheel wells, but could also place them on top of each other in between the wheel wells. My question is how much will having about 1300lbs (960lb water 130lb bed and a few hundred lbs of gear/shelves) hanging off the back end effect my ride? Should I try and orient the tanks as central as possible? I’d prefer to put fresh tanks further aft behind the wheel wells, but I could but them right over the axel, and I could maybe find grey tanks that fit between the frame rather than on either side. Thanks for input!
Tawdbb is offline   Reply With Quote
Old 02-14-2020, 01:13 PM   #2
It's not 960lb of water, it's half that. Your gray water and fresh water won't be full at the same time. Weight-wise, that's a couple seats full of kids.
Old 02-14-2020, 02:06 PM   #3
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
What about blackwater?
Sehnsucht is offline   Reply With Quote
Old 02-14-2020, 02:09 PM   #4
😅 true! Also, no black water, I’ll ya e a composter. Ok I’ll plan on putting them further back👍
Old 02-14-2020, 02:32 PM   #5
Chassis: Ford F53
10-4 on the composter, that's why I asked the question. With all the different options out there it is difficult to assume what anybody is going to use.what I might think is a good idea doesn't necessarily meet somebody else's expectations so no reason to offer a solution that doesn't solve a problem!
Old 02-14-2020, 11:48 PM   #6
You make a good point about not answering until all te data is available. In a forum such as this, it is difficult to do.
Old 02-15-2020, 05:33 AM   #7
Chassis: Ford F53
I've done it before. I make a comment from my perspective without considering my preconception on the subject. In this case, just because might think black water is a foregone conclusion doesn't mean it is so because composting toilets are very common in this application.
As a general rule I prefer to keep holding tanks between the axles but this isn't inflexible. Just remember that fluid is always in motion as you travel and with larger volume gains its own momentum to influence your handling. However I don't anticipate any issues in the proposed volumes and configuration, as Drew Bru said it's the equivalent of a couple of kids and we all know they gravitate to the back rows first anyways!
