Old 09-12-2023, 10:44 AM   #1
Chassis: Front engine flat nose
Where to put the water filter?
I have 150 gallons of fresh water tanked. I have a Clearsource Premier RV Water Filter System and a HQUA-OWS-12T Ultraviolet Water Purifier Sterilizer Filter for my skoolie. Should I install them before water enters my holding tank or after the tank, before the pump?
MadCompSci is offline   Reply With Quote
Old 09-12-2023, 10:49 AM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Having seen the inside of some tanks, over time, I'd filter after the tank. But, ideally, you'd have some kind of basic sediment filter on the tank fill to minimize the junk that enters the tank.
Old 09-12-2023, 11:18 AM   #3
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
I would run the filter before the tank and the sterilizer after the pump on the kitchen/sink lines, and I wouldn't worry about the shower lines or anything else.
But I also wouldn't be running a sterilizer on my water unless I was an AIDS patient or was otherwise immunocompromised because I had an organ transplant.
Albatross is offline   Reply With Quote
Old 09-12-2023, 11:37 AM   #4
Chassis: Ford E450
Engine: V10 Gas
I have a sediment filter just before the pump, and my water filter is only on a single faucet in the kitchen sink (for drinking water, cooking etc.).
The rest of my faucets and shower etc are not purified.
Old 09-12-2023, 12:17 PM   #5
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
This, I think, is the way to go.
Old 09-12-2023, 12:30 PM   #6
Tejon7's Avatar
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
That's what I did too and it's working well so far. My filter leaks sometimes, so I have it mounted in a shallow plywood box lined with shower pan liner material. I intend to put one of those leak detector alarms in the box, but haven't gotten around to it yet.
Tejon7 is offline   Reply With Quote
Old 09-13-2023, 06:22 PM   #7
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Just an aside...if you mount a micro switch above the bottom of your leak area, use the normally closed contacts and rest the actuation arm on an aspirin it makes a very reliable and inexpensive water leak detector.
Rwnielsen is offline   Reply With Quote
Old 09-13-2023, 06:36 PM   #8
Tejon7's Avatar
Rated Cap: 90 (40')
Clever!
This idea led me down a brief internet search rabbit hole. An even cheaper version I saw was a DIY "switch" made by gripping the aspirin in a clothes pin between two wires. Along with the 12v air horn I have in the garage, I could have a working water detector tonight!
Old 09-13-2023, 08:14 PM   #9
Rwnielsen's Avatar
Rated Cap: U/K
Clever!
That's pretty clever, crude but effective
Old 09-13-2023, 08:18 PM   #10
turf's Avatar
filters work better after a pump.
the suction or head of most pumps would barely pull water through a coffee filter. im surprised you folks are saying you have good results like that.
there is no chance a little rv demand pump is going to pull water through multiple cartridges of your clearwater premier rv water filter. that thing will have to go after your pump.
most would have a prepump screen to catch bugs before they get in the pump, and then a cartidge filter after to clean the water. you'll want a big pump for multiple cartridges. try and find paper cartridges for it or pull one if your pump loses to much pressure with it.
Turfmobile Build Thread
Old 09-14-2023, 11:12 PM   #11
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
You could install a sediment filter on the inlet to your water tank to keep junk from getting into the tank. Then the pump with suction screen followed by the cartridge filter then the UV sterilizer.
I would treat the water with chlorine when you fill the tank to keep things from growing in it provided that the cartridge filters remove chlorine.
Ted
