Old 03-20-2023, 10:55 AM   #1
Chassis: Safetyliner
Engine: Cat c7
Window in the shower?
Before I leave the original bus window in place in my soon to be tiled shower, I thought I would ask if anyone who has done this has experienced trouble with mold/mildew or other water issues.
it's not too late to "delete" the window, Id like to leave it in but I don't
want to create a host of problems.
Thank you for any input you might have!
Chrise
Chrise is offline   Reply With Quote
Old 03-20-2023, 06:06 PM   #2
Chassis: Ford E450
Engine: V10 Gas
Not something I would do, especially with tile and other labor-intensive and permanent finishes.
My choice was not to delete windows. Consequently, I needed to account for access and things like condensation. My solution was to build my interior standing free from the exterior wall (secured at points in the ceiling). It's a half wall with a clear shower curtain. That gives me air circulation, and more importantly, access to the window to monitor for condensation and leaks.
Old 03-21-2023, 06:19 AM   #3
Coachwork: Thomas Built Freightliner. Allison 2000 tranny
Chassis: Freightliner FS-65 (dognose)
Engine: Mercedes MBE 906 six cylinder diesel
Rated Cap: 35 feet long
I see you have built a plywood floor sloping to the drain. What do you plan to use to make it waterproof?
And how will you make the plywood walls waterproof?
David from Ontario is offline   Reply With Quote
Old 03-21-2023, 09:59 AM   #4
Chassis: Ford E450
Engine: V10 Gas
The base is a separate piece. I fiberglassed the joints, then did a few resin pours to finish. It was a lot of work and my notes say something like 'just buy a home depot shower pan next time.'
Walls are painted and polyurethaned. The bus is only used for short trips, and the shower is used infrequently, so I didn't have the same design requirements as a full timer.
