Old 09-25-2023, 11:08 PM   #1
Coachwork: Blue-Bird All American RE
Chassis: F204270
Engine: Cummins 8.3 ISC
Would 2 of these work for a recirc tank shower
And would this be cheaper than trying to find a single tank?
jfmusic@me.com is offline   Reply With Quote
Old 09-26-2023, 12:54 PM   #2
Two of what? You didn't post any pics or links or descriptions of what you're talking about.
Old 09-26-2023, 04:04 PM   #3
Chassis: F204270
tried to post the pict twice will try again
Old 09-26-2023, 04:04 PM   #4
Chassis: F204270
Pict
Picture of Bottle
Old 10-06-2023, 08:14 PM   #5
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Ummmmm
I'm sure you could make it work somehow but I served a career in the Marines and have bathed out of a helmet, a pot, and even a fire truck.
Even with that background I'd say NO for a skoolie.
Get an actual tank, install a set of filters between it and the shower head, drain back into the tank. Have a way to drain the tank to a grey tank (pump, gravity, etc.) as most places it's illegal to dump even shower water on the ground.... strangely it seems than an outdoor shower is generally accepted even though all that water goes on the ground.... hmmmm
HamSkoolie is offline   Reply With Quote
Old 10-06-2023, 09:04 PM   #6
Originally Posted by HamSkoolie View Post
Ummmmm
I think that’s because the kitchen is commonly plumbed to the grey tank when it is considered black water by the EPA
Old 10-07-2023, 12:29 AM   #7
HamSkoolie's Avatar
I think it's more the fact that there are so many recreational vehicles these days that it's the soap and such in the grey water. Otherwise they could just classify the sink water as black water which is already prohibited. The problem with that is that RV manufacturers or DIYers would soon be using separate tanks for sink water.
For instance, our design has a separate holding tank for the kitchen and bathroom sinks and a second tank for the laundry machine and shower. That tank will then be filtered to yet another tank which we've designated as the reclaimed tank that will be used for shower, laundry, and toilet flushing.
A 30-45 gallong reclaimed tank holding water from the shower/laundry holding tank will be refilled via screen, cartridge, and then reverse osmosis filtering with a final step of UV sterilization. Our Splendid all in one washing machine (which we found at Habitat for Humanity Restore for $100 in perfect working condition) only uses 15 gallons on the highest use settings and about 10 on normal (for a full load) so even a 30 gallon reclaimed tank would usually leave 20 gallons for showers and the RO is supposed to be able to refill that 30 gallons at a 400 gal/day rate (I'll be happy at less than 100).
The whole purpose is to make our 200 gallon fresh supply last 30 days or more.
