All chemistries will reduce longevity in hot ambient temps, and most drastically reduce performance in the cold.
LFP you must be much more wary of cold temps than lead, can easily render the whole bank instant scrap when charging at too high a current rate, as you get to even cooler temps, not to mention freezing and below.
With all chemistries, maintenance protocols like capacity benchmarking, manual rebalancing LFP or equalizing FLA, are best done from shore power with specialized adjustable gear, not the usual off-grid charge sources.
