The schrader valve on my A/C compressor is visibly leaking oil. When you unscrew the cap, a bit of pressure is released.
I got a type of tool that I randomly saw on a youtube video that allows you to replace the valve core without discharging the system.
1) Put quick-connect tool on valve.
2) slide valve-core "socket" on a long bar down through tool
3) engage with valve-core,
4) twist counter-clockwise to unscrew the core,
5) pull long bar back up through tool
6) close ball-valve in tool
7) unscrew "long bar" assembly
valve core should be there at "socket" end of bar, or in tool above ball-valve.
9) reverse with new core to re-install
Yet the valve core is not there....
plenty of pressure built up in the tool....immediately
I can spin the socket/long-bar part, feel it seem to engage with the core, and after a bit of rotating, I feel something that seems like "threads" that have reached max....it pushes out as I spin until one point, then drops back in, and starts pushing back out again until that same point in rotation and it drops in again.
Looking in the valve before I started, I saw that the hole that the core sits in is a 2-step bore, both steps threaded. The bigger diameter bore, closest to the hole opening, is threaded for the cap, while the core sits deeper in the smaller bore.
I'm wondering if my core is free of its smaller bore, but is cocked a bit sideways in the larger one (with bigger threads, I think), and that is the feeling I'm feeling.
Seems like if I can't finagle it to come out, but it is unscrewed even a little, I can't take the tool off. Can't re-install the compressor or therefore drive the bus.
Do I have to buy a vacuum pump and suck out the system through the low-pressure valve?
The youtube video made it seem like spreading warm butter on hot toast.
In my pic, the main tool body is on the valve, and the socket on a long-bar is on the wooden block on the ground
I'm gonna try some more (wearing a welding helmet so I don't blast myself in that small space hunched over under the bus), but if anyone has a comment or suggestion, fire it up!
