Originally Posted by Choc Lesnar
I'm consider purchasing a small air conditioner for the bus, it runs at 5400 BTUs. I currently have 8 solar panels at 260 watts each (a total of 2,080 watts) what size inverter do you think I should purchase? I haven't bought the batteries yet, I just wanted an idea. I was thinking if getting a 3000 watt inverter. Any ideas or suggestions would be greatly appreciated. Thank you!
A couple questions that will help define an answer:
1. Is the AC a minisplit (inverter AC)?
2. How efficient (SEER or EER)?
3. Will you have other large AC loads that might occasionally run simultaneously?
I would also second John's point that there is a substantial difference between a cheap Amazon/Aliexpress HF inverter and a robust high quality LF inverter from a reputable brand.
